Softsynth sequencing.
  • Thread starter Thread starter Lempface
L
Lempface
So I've decided to try to do a hybrid of softsynths/guitars/vocals and make some sort of electronica song in the vein of dntel/styrofoam. Well thats all well and good, I've got a massive set of synths, synth design suites, plugins from compressors to noise reducers to sound maximizers, samples from A-Z and a brain full of ideas. BUT BUT BUT.
I can't figure out how to sequence them.
If I start it up in Cubase and track a midi either from tabit or draw it on the staff right in Cubase I can hear my synths and wow its cool and yadda yadda. However when I try to route a second track through another softsynth? I hear.. nothing. Nadda. The only thing I can do is bounce the first track to a new track and then set the second track up for the softsynth. This is a pretty big pain in the ass because on a 4 minute song it takes about 2 minutes to bounce that track.
MORE IMPORTANTLY I can't hear what my synths sound like combined so I can't get any semblence of what the mix is going to sound like until after I boun to track. So wait 2 minutes, take 2 minutes to change settings again and find out that it didn't fit at all. Repeat making minor adjustments? You're looking at 10-60 minutes just to see if you can get two tracks to mesh. And that is only going to get exponentially harder as I add more tracks.
So my question is:
Is there a program, or am I doing something wrong in the ones I already have (Cubase, Audition, Sonar 4, Protools), that will let me play back multiple softsynths (Even if they are at a 15-20 second buffer) so I can hear my mix before bouncing the track?
it sounds like your doing something wrong. i use cubase sx2 and can have multiple softsynths. what softsynths are you using??? check that you have set them up correctly and you have selected the correct channel on the midi info on the left of the screen as some synths only work on chn 1.
I'm using Reaktor 5 and Absynth 3.
as luck would have it, i don't use either of them. but your definately doing something wrong, its just a matter of figuring out what!!! on cubase when you select your vst instrument, on the left of the screen make sure that you have your sound card selected for the in, and for the out select your vst instrument, underneath this try setting the chn to 1, thats all i can suggest without knowing your whole process but like i said it sounds like your doing something wrong, sorry i can't be of more help.
