digmudvayne4lif
Does anybody know of a plugin or something that will help smooth out the equalization of a mix or is doing it manually the only way?
digmudvayne4lif said:Does anybody know of a plugin or something that will help smooth out the equalization of a mix or is doing it manually the only way?
Please do a search at this forum on:digmudvayne4lif said:...after I mix down the final track and look at it with an frequency anylyzer, there's alot of hills and valley across the whole thing. Then when I put an anylyzer on a commercial song, its alot "smoother" (less/smaller hills and valleys)...
Yeah, it's called "mixing"digmudvayne4lif said:thanks for the help. so are you saying i should try working on the eq a little more the the indivdual instruments eq before the mixdown?
. Purposely waiting to fix a bad mix until mastering is as bad as purposely waiting to fix bad tracking in the mix.Why?digmudvayne4lif said:Cause right know after I mix down the final track {I} look at it with an frequency anylyzer
RAMI said:( No offense, Lee, I consider you an expert and I realise you were exploring the possibility that he said "EQ" but might of meant meant something else).
That's just gonna make us run over to the other Temple of the Audio Gods and put on our Loudness Warpaint!digmudvayne4lif said:... I guess what Im really asking is why I cant get it as loud and what I can do to fix it?
) . Don't overload either of the dynamics processors - I barely push into them, normally their metering shows no GR (gain reduction), just peaks every 8 or 9 mearures get lopped off at about 0.2db to about 1.5db or so. That's where I like it for this particular piece - it changes depending on the song of course. Splitting the job up into 2 dynamics processors was the key for me so far, the first one smoothly brings up the loudness (even though the meters show no GR the thing is still pulling the audio up gently), the 2nd limiter lopps the heads off anything I don't want poking it's head over the ceiling (-0.2db). You can generally hear when software limiters have had enough - all you can do is back off or try to split the job up.
