T
trickster223
Hi everyone.
I recently purchased a Red5 RV6 Condenser Microphone. Loving it so far, but one problem. The mighty buzz. I can't figure out what is causing it, i've tried everything, separating wires etc.. I have the microphone sitting on my desk and I am using balanced XLR cables, although I do a have a bit of a
different set up to what most people would use.
My red5 condenser microphone goes into the input of the phantom power supply (Stagg PCO-S PSU Mic/Microphone Phantom Power Supply) with a usual XLR input cable female/male, and the output cable is an XLR TO 6.3mm STEREO JACK, which then goes into the back of my DM2050 Numark Mixer. The mixer lets me control the gain, and then the RECORD-OUT from the mixer goes into the 'line in' on my PC (using double phono cables to single stereo line cable.) Search google images for 'phono to line cable' to see what I mean.
I recently ordered an M-Audio Fast Track USB Interface to use instead of my mixer. I'm hoping this will reduce the hum. It hasn't arrived yet though.
Is there anything you can suggest for me to do in the mean time that could fix the cause of this hum? Is my setup bad? Have I got a bad phantom power supply? Wrong cables? Something not 'grounded'? PC static?
Also as I mentioned before, all of the XLR cables are balance, except the phono to stereo cable.
I'll try and get an mp3 of the buzz in tomorrow morning.
Help would be appreciated,
Thanks,
Dan.
Thanks,
Dan.
