Sliding tom mount?
  • Thread starter Thread starter Drummyjoey
D
Drummyjoey
Are these any good? Do they usually just slide closer and farther away from the player or do they ever have a fuller range of movement (e.g. side to side)?
The sliding mounts that I have seen only slide front to back. I don't find them any different, the only thing that they don't do is put a big hole in your bass drum but they limits you on the hight of your toms sometimes. In a nutshell there is no difference either way there will be toms mounted on your bass drum.
Ok thanks, Brad. Maybe I'll look at other options then...
if your looking for something good, check out the system that is found on the gretsch drums, there are many other companies that does the same thing.
Slouching Raymond
Replies
13
Views
1K
DrewPeterson7
DrewPeterson7
B
Replies
11
Views
701
BaronEstelle
B
famous beagle
Replies
6
Views
263
famous beagle
famous beagle
