LemonTree
Suck 'em and see!
When inserting a delay or reverb on an FX bus, insert it in the second or third slot. This will give you added flexibility, in case you find you need to place an EQ, for example, before the effect to tailor the frequencies going into the effect.
He's using cubase 4? you can drag and drop the sends and inserts into any order. Atleast you can with C5 that I'm using and if I remember rightly you could with CS4 that I used before
