K
KevinDrummer
I would think that you would want to have the "hottest" signal at the earliest point - but I'm unsure.
What's the proper way to set levels? Here's a sample signal chain...
vocals --> into run of the mill dynamic mic --> into Behrinhger mixer --> into standard PC sound card --> into Cakewalk
I can adjust the trim on the mic pre on the Behringer, adjust the level (channel or main) on the Behringer, adjust my "line in" level on my PC, or the trim in Cakewalk (not sure what that is really doing). What is the procedure to get the best cleanest signal? Would it change if I running a drum overhead? When I arm a Cakewalk channel, I get a flicker on the meter with no signal (at about -66 to -48 db). I'm looking to clean it up. Help. Thanks!
