got hold of a manual and been reading, it quotes:
"All models have line inputs connected by internal wiring to the corresponding tape input. Eg. Model 168 line inputs 1 to 8 recieve the same programme as tape inputs 1 to 8. When you plug a different source into these line inputs the internal connection from the tape input is switched off"
So, armed with this info theorectically I should be able to put 1-8 tape outputs (XLR - jack) to the ADAT input and 1-8 tape inputs (jack - jack) to the 1-8 ADAT outputs. When the recorded signal comes in through the tape input it *should* appear on the corresponding channel 1-8? where i can then mix away, pan, eq etc etc
Am I correct with this assumption?
