Hi,
My 414 mki (original owner!) is generally noisier than it used to be. Particularly, one channel is quite noisy on playback even if I have nothing plugged in. It's similar to white noise and I can eliminate it by turning down the channel's volume. It does get worse when I turn the trim fader up from Line to Mic, so it's not like it's stuck at Mic or something.
What kind of culprits should I look for here? Any caps that I should replace (even if I don't see any bulging)?
The trim and volume faders are a bit sticky-- could the noise come from dust? I have used Deoxit D100 from the surface but would need to fully disassemble the faders to really get the dust out.
