B
Bob_D
Hi there,
Apologies but I am new to this forum and this is question is about the first condenser mic I have ever bought, so I'm a bit of an amateur.
I bought an SE1000a condenser mic to record at home. I use a laptop and Adobe Audition 3.0. Everything I record (electric drum kit, guitars, etc.) is done by plugging the instrument into my Line 6 Pod XT Live multi-effects pedal, which in turn is connected via USB to my laptop. I used to record vocals this way as well using a Shure SM58 but the quality was quite bad so I thought I would buy a decent mic.
The problem is basically that it is not working. There is no sound being picked up at all. I'm pretty sure the mic is ok and that's it's something to do with my setup. I have a lead which is XLR -> normal jack (if that makes sense). Basically it's not a normal XLR lead as the Pod XT Live only has input and output connections for normal leads (used for guitars).
So everything is working fine expect this new mic that I have bought. Am I missing something like an important piece of equipment? Is the mic too powerful for my setup to deal with?
Any help or advice would be welcomed.
Thank you,
Bob D
Thank you,
Bob D
