Well, you know the overheads are V63s. The toms are sm57 clones from GLS audio, the snare is a Superlux ECO-H6A (a side address electret) The kick is a Superlux FK2 kick mic blended with a homebuilt 8" subkick (just barely added). I have an MXL 603s on the high hat. Everything is run through an old Ramsa mixer using the built in mic pres. There's no EQ on anything except I boost the 4khz on the kick mic and boosted 2khz and 6khz on the snare because I'm not using a bottom mic. I probably will later.
The drums are Tama. Cymbals are Paiste and Wuhan. The room is my guitarists garage that we sound proofed with layers of sound board and insulation. There's a false floor and a 4" riser for the drums to isolate vibration. The walls are carpeted so I added a touch of reverb to make it sound like a larger room. That was added to a room mic.
I have a Symetrix SX202 preamp that I use for vocals. I'm going to try that on either the overheads or the kick and snare. I've got a couple of Presonus tube pres that might work too.
complexprocess, I have a pair of ECM8000s that I might throw up and lay down some samples if you can wait a week. I'll be on vacation, but when I get back I'd be happy to record something.
