Ignatius-
Member
I picked up this beauty a couple months back and just recently replaced the tape loop. It sounds great, but a couple of the heads are really out of alignment. It has a five head setup: I believe it's erase, record, playback, playback, playback - but I could be wrong about that... The erase head and record head are obviously out of alignment, but the playback heads appear to be okay. Instead of erasing after each pass of the tape it creates this kind of distant tape loop (rather than a pure echo) that keeps changing - it's actually really cool, but I might want to use it for a clean echo/delay sound sometime.
My question is - because I really don't know anything about aligning a tape machine (or echo machine) - can I adjust the erase head and record head without the equipment that I feel like I need? The heads have a crazy wear pattern because it's so old, but it sounds awesome (these are full-track 1/4" heads)... Simply, there are three screws in this spring mechanism that seem to adjust the "height" of the heads (it lays down flat). Can I just eyeball it? Trying to keep it as even as possible? And would this wear pattern effect the tape as it travels across the heads when/if I adjust it?
I kind of gave up on the DIY aspect of analog (I haven't been able to commit like some of the rock stars on this forum), but since this machine doesn't call for [extreme] accuracy in reproduction I thought I might give it a go on my own... Thanks for any thoughts you guys might have!
. Good thing I haven't put that many hours on mine... it might have to chill until I figure this out. I'm picking up my R2R from a great technician in town tomorrow, so he might have some useful information I could share...
