SaSi
Hello all, I am new here - found this forum googling for relevant information. Nice forum for recording enthousiasts.
I recently acquired a Revox PR99MkII. It is in generaly good condition. The heads and pinch roller appear to have been recently replaced as they show no signs of wear.
I have two mechanical issues to correct.
Firstly, I need to find replacement tape tension arms, as the existing ones appear to have been worn and have a tape width flatout. I am looking at ebay for that. Are there any other - better sources?
The second thing that troubles me is the NAB adapters. The unit came with Revox NAB adapters with aluminum handles.
NAB reels appear to turn irregularly - decentered.
I have confirmed that the reel plates and shafts are centered as using plastic Revox 10.5 reels without NAB holes gives the machine a perfect run for the tapes.
I can visually identify that the NAB reels rotate decentered. Like the one of the three plastic discs in the NAB adapter is protrudes more and forces the reel to decenter.
I have changed disks and rubber rings to the NAB adapters and saw no improvement.
Checking the adapters closely, I can feel they are somewhat worn and I can force the upper part of the ring (the one that fixes the reel) to decenter relatively to the bottom part (the one that is in contact with the reel plates).
I tried to take one adapter apart and check for wear inside, but could not separate the two parts of it. Removing the Revox decorative ring didn't reveal any screws or latches. I feel I cannot take this apart unless I break it. And the service manual makes no reference to servicing the NAB adapters.
I tried different makes, a pair of TEAC plastic adapters, but they are thinner and are not fixed on the plates as well. FF/REW generates severe vibration with them, so I need to go back to the revox design.
I have seen several NAB adapters on ebay but all appear to be used and I fear they have every reason to show the same symptoms.
Apart from buying empty Revox NAB-less reels and transfer all tape on such reels, is there any other idea on how to fix the NAB adapters or a source for good quality new ones?
Any pointers would be valuable,
Thanks in advance
Thanks in advance
