Hi all hope im in the right section. I have a problem with recordings sounding distant. Ive read similar threads but no solution, some of you were asking the OP to post a clip but they never came back to the thread so I thought id post a clip. Thanks for any help.
Stagg MD1500 mic
charvel charvette guitar
vox valvetronix 60watt amp
nio 2|4 novation audio interface
Amp settings are no reverb, no delay, no effects, medium levels and low master volume. When I add reverb or delay in the mix it makes the guitar even more distant.
The mic is pointing directly at the centre of the speaker and as close as possible, but it doesn't matter where I put it the recordings all sound distant, using EQ helps a bit but adds noise.
edit: I think its a carbioid mic, ive read that these mics dont accept sound from the sides and rear so i tried wrapping the mic in socks and the mic was much much more sensitive, but on playback it was pretty much the same as normal, very frustrating, weeks of playing around and same bland tone.
Also I had the exact same issue when using an SM57 and a Marshall AVT150 last year.
Stagg MD1500 mic
