M
MiNuS...
Is there a difference?...what would be better...i know that panning effects work better on stereo...
SP Tech Continuum ADMono more or less. Unless you're trying to capture some stereo aspect -room, group image, movement.. what else?
Panning is in some ways simpler or more versatile in mono.
___________
I guess it depends - it might be worth a shot Y-routing mic signal. Clean sound to one channel and the double of it thru some effects bus - say reverb+phase (kinda like Van Halen's guitar in Aint Talking Bout Love intro), then blend/pan them in a mix...
Must have missed it. I presumed MiNuS meant two mics/stereo.Massive Master said:One mic, one source - MONO.
..You can run it to a stereo channel and it'll be MONO. You can run it to 6 channels and it'll be MONO...
..Jeeesus, how many times do we have to go over this stuff in one day?
Just do a aux send.. Don't even need stereo or second track for that.
..goes with out saying..Unless you're a real masochist![]()
. Jack Johnson's latest album is a great example, having used an original demo U47.Care to expand?..But don't forget, the dimensions will come later during mixing with your time based FX.
Fig 8 picks up room/backside -comes up in compresion make-up gain(?) What about the time effects?
SP Tech Continuum ADYou're not going to hear a difference -- 1x mono = MONO.Thanks...i can kinda hear a differences...mono sounds more natural...
Care to expand?Fig 8 picks up room/backside -comes up in compresion make-up gain(?) What about the time effects?
___________
Monitoring just fine at CathouseSoundSP Tech Continuum AD
If it isn't, then seriously dude, like it has been said, mono is mono no matter how many channels you route it to.There is no such thing as stereo until there is a difference between the left and the right. One signal is not and will never be stereo. If you want to record a dozen vocal tracks and pan them all over the place, you'll have stereo at the buss. If you take the *same* audio information and pan it all over the place, it's still a single source (although it may favor one side).
but some peeps don't...One mic, one source - MONO.
1 = 1. 1 does not = 2. 1 to the first power is 1. 1 to the 57th power is 1.
Doesn't recording it twice give you two sources?If you can sing the lead vocals same the same way twice, track them twice and pan 20 L and 20 R...sounds good to me...i like it.but some peeps don't...
