gianelli280
I don't think so.
that bad eh?
I don't think so.
Yes. Or.. lose the compression all together, and possibly even go cleaner so it articulates with more dynamic/transient.Something else you might want to try to do is compress the lead quite a bit to really smooth it out, then add any EQ after the compression in the chain...
Panning!!! Panning your rythm instruments away from center and leaving your leads in the center will help them.
your clip is mono.i centered the lead and put rhythm about 40% right, cut rhythm down a bit too.
i also tried to put a condenser about 3 feet back but the program i'm using (poobase le4) won't allow me to put it in phase so it sounded like dookie... well, more dookie than before.
How does one ensure this? Are you saying all frequencies are aligned?It's crucial, when mulit micing one source that you check your mics in MONO to ensure no phase cancellation.
PHase issues should be addressed by mic placement not by phase allignment software. It's crucial, when mulit micing one source that you check your mics in MONO to ensure no phase cancellation. Adjusting the mic placement should fix that issue.
ok that should be in stereo, let me know if it isn't.
so bring out the bass more as in guitar tone, or bass guitar itself? and i don't own a saturator of any kind, but i do have an external tube preamp, give that a shot?
i'm pretty sure i panned rhythm hard left (or right, can't remember) but i'll double check.
I meant more out of the bass guitar itself,
because it's supposed to be the body of the song,
and a song can fail only because of a bad bass.
I can guess that the tube preamp will add some kind of warmth,
because you need a bit of warmth in your guitars.
