Recording high gain distortion
  • Thread starter Thread starter skiz
skiz
Im recording a cover of an as i lay dying song with a couple of mates and im having a real hard time with the guitar. The guitar is just way too crunchy and distorted. I turn the gain down a LOT and it still seems to get a lot of fuzz when its recorded. Whats a good method for getting good distorted guits that still have nice tone? Is it just a mic placement thing? Cause the distortion coming frm the amp really doesnt match the recorded sound
you're probably pushing the mic to hard. you only need the gain to where it just starts to be saturated. obviously not clean, but not like on 10. what kinda mic and pres are you using?
The amp is a peavey valve king. The mic is an audix I-5 and the pre's are just the pre's on my firepod. I dont think im over loading them tho cause we tried all sorts of amp volumes and i set the levels on the firepod accordingly so it doesnt clip etc.
sounds like your signal chain is pretty decent, nothing to be worried about here.
next step would be to get down near the speakers and adjust the tone while listening down where the mic is going to be. make sure that you aren't scooping out all of those precious mids, you can play with that sound after tracking if you need to, but you can't easily put them back in after the fact.
you want to start your miking journey with your mic in the center of the cone, the area surrounding the dustcap, but not on the dustcap itsef, so halfway between the center and the outer ring. as you may have already found out, moving it outwards gives you a darker sound, while moving it inwards gives you a brighter sound.
if you have another dynamic mic on hand, a second mic on guitar cabs adds a whole new dimension to the sound. but it also brings in phase relationship problems that aren't too fun either.
but good luck with your tone search and post some clips if these basic techniques don't change anything.
cmharwood89
Replies
3
Views
1K
cmharwood89
cmharwood89
themindwillnotletgo
Replies
38
Views
6K
themindwillnotletgo
themindwillnotletgo
