killthepixelnow
Do it right or dont do it
Hello guys, I'm about to record bass for an album and I've been wondering if you find my approach correct. OK, here's the rig:
BASS --> Compressor --> Bass Attack --> DAW --> Computer
I'm using the bass attack as a DI Box, one signal goes crystal clean and the other have some distortion and EQ applied (later on I will mix those signals to taste).
My big concern is that, although I tame the peaks of the clean signal with the compressor, I'm squashing the other signal too much since there's a compressor and a distortion at the same time.
What do you think? Should I get rid of the CS3 before the Bass Attack pedal?
I'd really appreciate your input on this issue. Thanks in advance!
