Atkron205
Member
I have Reaper ver 6.13 installed with a UR824 interface. I have the interface assigned in Reaper and in a session can assign the inputs and outputs on the interface. The UR824 has a program called DSPMixFx that is used to change settings on the interface. This program seems to be over riding Reaper. For example I can connect a mic to one of the inputs and it works as far as running through the interface, I get signal from the interface to my monitors, the issue is Even though I can see the interface and all the inputs/outputs in Reaper I cannot get Reaper to manage the interface. I have tried uninstalling the DSP program with no results, The interface works the same way without Reaper open as it does with it open.
This is the DSP GUI and the interface settings in Reaper
Thanks
Thanks
