seeeker
Surprisingly, the two books I purchased and PT Help itself does not explain exactly how to manipulate and edit volume throughout a track. This defies all logic how such elementary instruction could be absent, but oh well.
Basically in the middle of a track I want the volume to go down to a certain level, then several seconds later, go back up to the original level. I want it to be precise. How is this done? At an anchor point, the volume is one number, then seconds later it's different, I know it's simple stuff but it's still not easy to figure out.
I would like to change the volume of a track in different regions. The only way I know how is to use the hand tool and click a point in the track to make an anchor point, and drag the volume up or down. But if I send the marker to the beginning of the track, set the volume at "0". Click a point a few seconds in and the volume has changed. I don't get it. There's an anchor point in the beginning, then at the spot where it starts to fade. I'm blabbering but it's just not easy to figure out exactly.
thx.
thx.
That's another way of automation. Good luck~LV
