miroslav
Cosmic Cowboy
So what exactly do you think varies at different levels between those extremes?
Not looking to answer for Glen....but I kinda gave that perspective some thought...and the only thing I could come up with was that he was suggesting that when levels are real hot=LOUD...it may affect our mixing decisions VS when levels are lower=softer.
BUT...that really isn't much of an issue as you would simply turn down your monitor level if the mix is LOUD....VS a song where everything was tracked at lower levels and you would turn up your monitors.
I mean...in either case, you will always adjust your monitors to whatever listening level is comfortable for you...so the individual/overall level of the tracks becomes totally irrelevant when inside the DAW....doesn't it???
You simply adjust your monitors and then balance out the individual tracks levels as you mix.
Now...when it comes time to sum out a finished mix...you still have to set to overall mix level to a point below clipping, since inside typical DAWs it's pretty much impossible to actually clip the mix while it sits in 32bit float mode.
Granted...if you always track following proper gain staging and you work within acceptable margins of typical analog gear...then your DAW levels will usually reflect that...without much need for concern.
IMO…the problems arise when people are operating their front end at the outer limits of its acceptable margins JUST to try and hit the DAW with a hot level because they read somewhere that was desirable….and while the DAW has no problem accepting a -1dBFS level…their front end is probably soiling itself putting out that kind of level…hence the crappier sounding tracks.
though I guess the more technical definition would be stuff like...distorted/pinched/compressed w/possible effect on frequencies...etc.
