E
Element77
First post! Big problem.
I got a 610, to replace a EMU0404. And I've had nothing but issues. Unless I'm an idiot I don't ever recall this problem before. I put a little test here (excuse the riff, just wanted to show the problem.)
When I record (in Sonar), I do 4 guitars. (100, 75) I'm using TSS, Lecto, and Gregs beta, that's all. I have everything at 12 o'clock (minus drive on the TSS, at 0) No eq's except HP and LP. The only difference between the 100 and 75 channel, is the 75 is -2db lower.
If I record the 100 and 75 at the same time, it sounds big (but still with some sort of odd phasey-ness to it.) But if I record the separately, there is a big drop in sound and almost sounds completly out of phase.
I recorded 4 bars together, 4 bars separate to show the difference, and then w/ no drums. If someone has had this issue, or knows where I'm going wrong, please help. I don't ever recall there being this big of a difference before.
James
James
