A
Alchemist3k
I have been working on a track recently and although I have basically now got all the parts worked out and I am relatively happy with the arrangement my mixing skill is pretty poor.
After trying some mixes that I wasnt too happy with I read some material and decided the best thing to do was reset the mixer in Cubase (VST 5.1) and get all my levels sorted out to avoid clipping. Now they are all set nicely and all instruments are hitting just under the 0db mark with no red lights showing.
The mix is currently dry. i.e. no effects or EQ yet.
My problem is that the track is basically entirely made up of VST instruments and this poses a problem because:
a) it uses a lot of processing power (luckily its a powerful PC)
b) more importantly, I keep hearing about compression and how you should use it on practically all tracks. However, Cubase only allows you to use its built-in compression on audio tracks.
Should I convert all parts to audio? I'd like to know what other users tend to do. I am having trouble making my LM4 drums sound very loud. They are at the 0db mark but all other sounds seem much louder.
I know I could run plugins and add compression to VSTi's that way but that would mean using up all 8 Send slots on compressors alone leaving me no room for reverbs etc.
PS I am still slightly confused as to what compression does anyway other than make tracks louder?
Lots of questions I know. Can someone clarify?
), though I tried a lot in the last couple of years...
