Rokket
Trailing Behind Again
Done and done....MadAudio said:I gotta be honest - something weird happened between here and there, because my drum track was a lot tighter on this end. It seems to be ever so slightly ahead at first, then seems to sync in around 2:30.
If I recall you're using Vegas, right? Vegas has a tendancy to automatically treat an imported file as a loop, and that can cause problems. To change that, right click on the waveform and select properties. The following box should come up. Just uncheck the loop box and hit OK.
