Or... just like we did in the 'olden days':
Open a DOS prompt ('MS DOS Prompt' from the Program Menu, or open 'Run' and type 'Command' and press <enter>
At the command line type in ftp ftp.p3.webhosting.yahoo.com
You will be prompted for a user name... Type in:
contestupload@sbcglobal.net@patden.com
At the password prompt type in: contest
You will then be connected to the upload directory
At this point, you will need to know THE EXACT LOCATION on your hard drive where you have saved your entry... easiest thing would be to save it directly on the C drive, not in any folders or sub folders (this is known as being on the 'root' of the drive) (easier typing that way.. I'm lazy)
So... assuming you have your mp3 saved to the root of your C drive, type:
put c:\your_entry.mp3
To insure your file is now in the directory, after the upload, type: dir
When you're all finished type: quit
Type: exit to close your DOS window...
Clear as mud?
