A
Aurora
Hey, I'm currently planning to build (with the help of my band) a room-within-a-room practice space and project studio in the basement of our house, and I wanted to check my plan with some of the veterans in this forum:
13' X 18' space, hopefully 11 1/2' x 16 1/2' interior dimensions, 7 1/2' ceilings (low, I know, but nothing can be done). The floor is concrete, we'll probably carpet it.
The plan is, from outside wall to inside: 5/8" drywall; special frame with good insulation; 1/4" drywall on the inside, covered by a material called "homosote" or something like that (acoustile stuff, but supposedly better) for the innermost layer.
The frame would look like this:
______________________________________
I_I I_I I_I I_I
_ _ _ _
_____I_I_______I_I________I_I________I_I__
with 2x6's for the top and sides (frame) and 2x4's for the studs.
And with insulation:
What kind is best for a project like this (low budget here, guys), and does one put insulation on both sides of the frame above, or just one to allow for dead air space? Or one person suggested we thread it through the beams horizontally, but that sounds maybe not so good.
Ok, hope that wasn't too confusing and thanks for sticking with me. Any suggestions? Should that be enough not to piss off neighbors? Anything that would be less expensive?
Rian
I_I I_I I_I I_I
_ _ _ _
Rian
Ok. Now we got the scoop. Have you looked at John Sayers SAE site? Probably, but in case you haven't, do. Heres the link below. Have you gone into the archives? There have been a thousand queries regarding the same thing. Of course, every project has its own little quirks huh! Any sliding glass doors? Ceilings at 7'6" huh! Those are always tough. But you do the best you can with what you got, right. Ok, as to the construction, are the existing walls already sheetrocked? I assume you play rock? Loud? Neighbors 10' away. Oh boy. Ok, like I said, I am not the resident guru here, I can help, but I by no means am an expert. Ok, starting with the walls. I would say, if they are already sheetrocked, you have a variety of solutions, depending on how much you spend, vs, how much transmission loss, you really need to obtain. Thats the bottom line. IF absolute soundproof is what your after, you HAVE to pay attention to details. As one member put it, a 1/64th" hole can negate ALL your efforts to eliminate leakage. But thats not all. The next villian is transferrance through the ceiling structure, to the exterior walls. That the tough one. There are 3 or 4 solutions to this on johns site, including adding sheetrock in the joist cavities, on the underside of the floor above. From there, I would think the insulation, then 5/8" sheetrock on resiliant channel. This helps decouple the sheithing from the structure. But air ducts, interior loadbearing walls, pipes, stairs and anything else that penetrates the ceiling has to be delt with accordingly, or your wasting your time and money. In this instance, structural vibration is your worst enemy. Room in a room is THE solution.
then I would suggest a different approach. Like a different location
