M
ma24
M-Audio Delta WDM 31 Beta Posted
Hello All,
We just posted a beta driver that alleviates the issue that Benjamin covered on his website. With Ben's help, we were able to reduce the delay offset down to several samples. Benjamin has already verified this.
Subsequently, Slackmaster has also been contacted directly about this updated driver.
Thank you Ben and Slackmaster for bringing this to our attention.
A word about the beta driver just posted. This driver incorporates updates to the WDM structure for an issue not related to this forum, subsequenty, this fix introduced additional latency that does not help Sonar users. This is made very clear in the read me document that accompanies the driver. Sonar users who require ultra-low latency should continue to use the 5.10.00.0027 WDM driver until a final candidate of the .0031 WDM driver can be released. The text readme included with the driver has been updated from yesterday to include an itemized disceration with what should be known about this driver.
We also introduced an update that allows for users of the Delta 44 card who want to sync the card with another Delta card without SPDIF hardware lock when using an ASIO application. This is done using a double buffer scheme that unfortunately WDM does not support.
The driver can be obtained at:
www.m-audio.com/support/driversearch.php
For the users on this forum and other forums that want M-Audio to produce better, faster, low latency drivers, please test with this driver and send your results and suggests to testing@m-audio.com. We welcome your input.
We are working on a revised version that will reduce WDM latency to ultra low levels, but we felt is was best to release the driver now as a Beta instead of hanging on to it.
In the future, we will be posting and corresponding on this website and other websites with similar forum issues.
Thank you.
M-Audio Testing and Engineering Dept.
testing@m-audio.com
ma24@m-audio.com
Hello All,
Thank you.
testing@m-audio.com
ma24@m-audio.com
