R
RWhite
I'm continuing this thread from one I started in the Cakewalk forum. You can see it here if you wish:
http://www.homerecording.com/bbs/showthread.php?threadid=62296
The short version is that my SB Audigy card will not work in Sonar 2.0 if I use WDM drivers. It will see the card as a recording device, but not a playback device, therefore it will not play audio. If I force it to use MME drivers, the card is detected fine and works fine. This is using the newest Creative drivers, installed several times - and I might add that each time I installed the Audigy drivers it crashed my XP system, and I had to use work-arround to get the install to finish.
After reading many comments that the Audigy's drivers were suspect, I finally decided to switch back to a SB Live card. I am planning on buying an Audiophile 2496 card soon anyways, but I wanted to start playing with Sonar now. But I encountered the same problem - the Live works fine under MME, but will not play audio under WDM.
Has anyone else experianced a problem like this? Furthermore, do I really NEED WDM? I have read a bit about it, I understand it supposed to work better and offer better latency, but is it really a big improvement?
