flatfinger
Use every dam bit!
So from the looks of the transfer graph on that GUI , What you created is much like the first limiter/compressors that came into existance in the 50's which did'nt really have a "knee" ; but the whole diagonal line that is linear gain in the transfer plot is just tilted or tipped on the center ("hinged") . The difference is that although your graph does'nt have a knee , it's not upward expanding the low stuff. (other than the effects of make up gain, right ??)
( so while you say the wave form was'nt significantly changed , it;s over all dynamic range was made smaller ( forced into a more compact overall footprint in amplitude ??) . just a volume control , gain change?
I don't for sure since I've never gotten my mittens on one personally , but many of the first boxes did'nt have allot of controls for the envelope behaviours. the Gui's on say , IK MM's emulation of a fairchild 670 , or the new PSP old timer only have one control for both attack and release .
Here is a reference to the page over at rane that I found . It presents an interesting take; a history lesson on the transfer function .
http://www.rane.com/note155.html
: SEE Appendix
So it is usefull to break what a comp does into two parts , Too me , the simpler part is the gain changes brought about by the transfer function ( which depending on the comp , can have many wild and wonderfull permiations) and then the more mellon-twisting aspect of the detector circuits envelope following activities ; with all of it's controls , and how it goes about deciding what to tell the gain elements what to do ( when and how fast to do it ).
All of that is before the more esoteric sound-changing elements some comps have , like adding analog colour and inharmonic distortion .
If you got this far TX for putting up with my ramblings !
I probably got something wrong . Comps are devilishly deep and complicated . Really challanging to understand ( I doubt I ever will completely), And I guess that's part of their charm .... you gotta like a challenge!!
Cheers
: SEE Appendix
What "compression" is and does has changed significantly over the years. Reducing the dynamic range of the entire signal was the originally use of compressors, but advances in audio technology makes today's compressor use more sparing.
Early compressors did not have a "threshold" knob; instead, the user set a center ("hinge") point equivalent to the midpoint of the expected dynamic range of the incoming signal.
With advances in all aspects of recording, reproduction and broadcasting of audio, the usage of compressors changed from reducing the entire program to just reducing selective portions of the program.
Cheers
