SouthSIDE Glen
independentrecording.net
Assuming a threshold above -inf (dBFS), yes, you're right. I was instead assuming the original proposal:But he said throw out attack and release, not threshold.
If you leave everything below the threshold alone and only affect the wave above the threshold, you will be changing the rise and slope of the wave. If you did it perfectly, it would probably sound like crap because of the distortion of the wave.
and that he still meant the same thing in his last post when he specified applying the compression "to each sample". This would mean an infinitly small threshold (or at least one set below the noise floor) in order to apply the compression to the the whole signal uniformly.mixsit said:Would there be a way to reduce the dynamic range of a signal by simple ratio and not include time' and threshold?
I may be missing something really basic here. But if you were to scale each sample's level value by say .5 would that make for a transparent dynamic range reduction with out the attack and release artifacts of a compressor?
That said, though, I do need to correct my last post on one other important thing. The output makeup gain will balance out the effects of such global compression and make it "invisible" only if the output gain is acting like a typical analog amplification circuit and actually multiplying the output voltage.
I'm not sure - I just don't know - if your typical output gain on a digital compression plug acts like that or whether it's a simple additive volume control (like simple peak normalization.) If it's simple additive volume - e.g. if when it's set to 12dB it simply adds 12dB to each sample - then the compressed signal will sound compressed and have less dynamics, even when you do try to equate the relative playback volume to the original uncompressed signal.
G.
