Pro Tools Compatibility
  • Thread starter Thread starter Versatile
V
Versatile
Is there someone who can answer the question of, can a Protools file(ptf.) Protools 7.3 le, be used in later versions of Protools(8,9,10,11)? I want to use Protools 7.4 session file in the studio in versions 8.0 and later! Any clarification of this could send me in the right direction it is a very formidable question at this moment. Thanks a lot! Versatile.
Hi.
Yes, you can do that.
10+11 will want to reformat the file to ptx rather than ptr, but you always retain the option to save a backward compatible copy.
Just be aware of the option and make sure you make the right choice.
I'm pretty sure it's not an issue between 7.4 and 8…It should just work straight up. :)
Thanks for the advice Steenamaroo, It is truly appreciated!I will give it a try... Versatile
