Printing effects onto tracks
  • Thread starter Thread starter walters
W
walters
When printing effects to a track how do u make it sound good when your layers effects
Like if im using eq's,compressors,reverbs,delays,phasers,flangers,chorus,tremolo
How should do the processing step by step
Do i Print the eq's first and then print the compression?
Do i print the reverbs and delays second?
What are some printing techniques u guys know about when processing effects please?
how was printing effects in the 60's or 70's was done was it taking the aux send going to a multi effects processor and then not returning it to the Aux return but to another input Channel?
How do u bounce and print the effect at the same time?
Since my 2488 has a AUX send if i crank it to just pure DRY signal 100% to the aux expander its like using a insert
But if i record a track dry the i can do PRINTING the effects by send the dry track out to the multieffects processor and the back to "Another" channel and then keep bouncing the track until u got like 6 Aux effects by PRINTing re-recording adding effects building the audio track until its rich and layered
My 2488 doesn't have automation so i have to PRINT all my automation the eqs sweeps per track the PRINT record the Pan sweeps then PRINT the volume changes of the AUX sends or SOLO and MUTO automation to record and print all these stuff one by one
They call printing=freezing a track now
You can print and bounce at the same time by recording the fx to another channel.
How 'bout some rep for Walters? He deserves some for effort!
Why doesn't the AUX returns print or record the effects fX it?
If i send track#1 to a AUX send to a multi effects processor to a AUX return i hear the reverbs or FX but when it records only records DRY in pre and post i hear no fx's printed only on mixdowns thats the only time
How do i get to record the FX in post production after i recorded a Dry signal to add reverb or flangering on the same track? without bouncing it ? so i can layer effects ontop printing them on the same track without bouncing it>??
Use this one.
It prints like a mean machine :cool:
Use your computer for recording and mixing instead of for figuring out how to do outdated processes on limited hardware and your problem will be fixed.
No one can write like Walters. Always a good read.
But buddy, I'm not talking recording with you until you post a song.
Tim
Vesicants and Blood Agents
Lewisite - A vesicant toxic agent, industrial lewisite is a dark brown liquid with a strong smell. Lewisite is a contact poison with practically no period of latent effect. Lewisite vapors cause irritation to the eyes and upper respiratory tract. According to the Center for Disease Control, lewisite would cause stinging and burning. Its smell, generally characterized as the strong smell of geraniums, could be confused with the smell of ammonia (the reaction to which is regulated by pain fibers rather than smell). Iraqi stores of lewisite were not located after the war according to the Department of Defense.
Cyanogen Chloride - The French first suggested the use of cyanogen chloride as a toxic agent. U.S. analysts have reported that it is capable of penetrating gas mask filters. Partially soluble in water, it dissolves well in organic solvents. It is absorbed easily into porous materials; its military state is a gas. Cyanogen chloride is a quick acting toxic agent. Upon contact with the eyes or respiratory organs, it injures immediately. Lethal exposures result in loss of consciousness, convulsions and paralysis.
Hydrogen Cyanide - A colorless liquid smelling of bitter almonds, hydrogen cyanide is a very strong, quick acting poison. Hydrogen cyanide affects unprotected humans through the respiratory organs and during the ingestion of contaminated food and water. It inhibits the enzymes which regulate the intra-cell oxidant-restorative process. As a result, the cells of the nervous system, especially those affecting breathing -- are injured, which in turn leads to quick death. An important feature of hydrogen cyanide is the absence of a period of latent effect. The military state of hydrogen cyanide is a gas. The toxic and physiologic properties of hydrogen cyanide permit it to be used effectively in munitions -- predominantly in rocket launched artillery. Death occurs after intoxication due to paralysis of the heart. Non-lethal doses do not cause intoxication.
Return to Top of Page
Blister Agents
According to the material safety data sheet (MSDS) for sulfur mustard gas (HD) prepared by the U.S. Army Chemical Research, Development and Engineering Center, Aberdeen Proving Ground, Maryland, "Chronic exposure to HD can cause skin sensitization, chronic lung impairment, cough, shortness of breath, chest pain, and cancer of the mouth, throat, respiratory tract, skin, and leukemia. It may also cause birth defects. (See appendix A for MSDS sheets on sulfur mustard agents HD and T.) The U.S. Army Chemical and Biological Defense Command lists the current detector sensitivity threshold for the M256A1 kits, a commonly used piece of chemical agent detection equipment in the Gulf War, as 2.0 mg/m3. According to the Material Data Safety Sheets for sulfur mustard, total weight average exposures of greater than .003mg/m3 over an 8 hr. period requires the use of protective equipment. (See appendix A.) Therefore, the detection kit would not detect the agent until the amount of agent present exceeded the safety threshold by a factor of over 660. The M8A1 automatic alarms do not detect blister agent.
Mustard Gas - This is a colorless, oily liquid which dissolves poorly in water, but relatively well in organic solvents, petroleum, luricant products, and other toxic agents. The injurious effect of mustard gas is associated with its ability to inhibit many enzyme systems of the body. This, in turn, prevents the intra-cell exchange of chemicals and leads to necrosis of the tissue. Death is associated mainly with necrosis of the tissue of the central nervous system. Mustard gas has a period of latent effect (the first signs of injury appear after 2-12 hours), but does not act cumulatively. It does not have any known antidotes. In military use it can come in gas, aerosol, and droplet form. It therefore acts through inhalation, cutaneously, perorally and directly through the blood stream. The toxic and physico-chemical properties of mustard gas allow it to be used in all types of munitions.
Related Chemical Agent Information
Committee staff has learned that Iraq may have acquired any one of a number of the Soviet binary novachok ("newcomer") series of chemical warfare agent compounds or information relevant to the development of those compounds. This series of chemical warfare agents reportedly contains both lethal and debilitating agents. According to a confidential Committee source, if the Iraqis had obtained samples of these compounds they could be easily analyzed and produced with readily available materials. Several of these compounds are described as agents that even in microdoses can have long lasting effects. These agents are described as inducing myosis, vomiting, memory loss, involuntary motions and internal organ dysfunction. Many of these materials are also described as having mutagenic effects. These materials are, according to the source, stored in the lipids (body fats) and have no known antidotes. In addition, according to the Committee source, the Soviets were believed to have conducted research in a number of dioxin-based chemical warfare agents, and on at least one agent that could be used to contaminate drinking water supplies. Committee staff is conducting further inquiries to determine if Iraq may have had access to any of these compounds.
Biotoxins
Biotoxins are natural poisons, chiefly of cellular structure. A distinction is made between exotoxins which are given off by an organism while it is alive, and endotoxins which are given off after a cell's death. The exotoxins cause the injurious effects of biological weapons, but endotoxins guarantee the effects of chemical weapons and do not cause the widespread disease outbreaks associated with biological warfare. Some examples of biotoxins include botulinus toxin and staphylococcic enterotoxin.
Biological Warfare Capability
According to the U.N., the Iraqi biological warfare program was initiated in mid- 1986 at Salman Pak. UNSCOM inspectors discovered evidence of research into certain biological agents including botulinus toxin and anthrax -- as well as organisms responsible for gas gangrene, tetanus and brucellosis, components of a biological weapons program which was not defensive in nature. In four years of work prior to the war, only 10 papers were published. These research programs focused on Iraqi efforts to isolate the most pathogenic spores. They also did research on the aerosolization and on the environmental survivability of some of these biological materials according to the United Nations.
While the Department of Defense maintains that the Iraqi military did not weaponize its biological warfare program, UNSCOM is less certain, reporting that their degree of confidence that weaponization did not occur is low. In fact, readily high performance agricultural aerosol generators could easily be converted to both decontaminate areas in which chemicals are used and to aerosolize biological and chemical warfare agents.
Other ways in which biological materials could have been weaponized include the use of Iraqi 250 and 500lb bombs, aerial rockets, unmanned aerial vehicles, FAW ground-to-ground missiles, helicopters and Iraqi aircraft. The Committee has received several reports of Iraqi helicopters penetrating Saudi airspace during the war by flying at low levels through the wadis and of Iraqi aircraft penetrating the area over the northern Persian Gulf.
According to UNSCOM, indications that suggested that the program was offensive in nature include:
* No declared links between the BW defense program and medical corps research.
* No links between aerosolization research and research on defensive filters.
The United Nations said that the Biological Inspection was initiated on August 8, 1991 at Salman Pak. The inspection was delayed because of the need to extensively immunize the members of the inspection team. The Salman Pak facility was razed one week prior to the arrival of the inspection team.
The United States is aware of the Iraqi potential for using biological weapons. The employment of biological agents in a "cocktail" mix with chemical warfare agents is consistent with Soviet military doctrine. It is clear that biological weapons are much more difficult than chemical weapons to detect and defend against. Some of the symptoms experienced by veterans suffering from Persian Gulf Syndrome are consistent with biological warfare agent use. Verification will require sophisticated medical diagnosis, which to date has not been publicly undertaken.
The question of whether U.S. forces were attacked with a biological agent is problematic. According to Chemical/Biological Program: A Department of Defense Perspective, "it has been recognized that our biological defense program was inadequate. Creditble analysis indicated that optimal employment of biological agents could result in a significantly large hazard area." It further cites a memo from the Chairman of the Joint Chiefs of Staff to the SECDEF (Secretary of Defense) noting: "inadequate ability to counter BW (biological warfare) attack/BW defense is a priority requirement. The inadequacy of the current biological defense and detection program was also supported by Deputy Secretary of Defense John Deutch in an unclassified May 6, 1994 address delivered at a Department of Defense sponsored counterproliferation conference at the Los Alamos National Laboratory. According to Deputy Secretary Deutch, the United States has "no biological detection capability deployed with any forces, anywhere."
Novel BW agents created by altering DNA plasmids and vectors are specifically intended to avoid detection. As noted below, several shipments of biological materials that might have been used to carry out such a program were licensed for export from the United States to the Iraq Atomic Energy Commission. In such a program, common intestinal flora such as e. coli could be altered to produce viral, bacterial, or other toxins and would be difficult to treat. If Iraq was successful in developing such agents, diagnosis will continue to elude physicians testing for traditional illnesses. Novel BW agents would certainly elude biological detection devices. There is evidence, based on the nature of the materials imported, that this type of research was being conducted. Since the Iraqi government managed to dismantle much of its biological warfare program prior to the UNSCOM inspections, we can only speculate on how advanced this program might have been.
It has been suggested that if these problems the veterans are experiencing are Gulf War related, then we should be seeing even more serious problems among the Iraqis. Since beginning this investigation we have learned that many Iraqi enemy prisoners of war (EPW) suffered skin rashes, sores, nausea, vomiting, coughing and other medical problems while they were being detained in Saudi Arabia. Many members of units who had close contact with these individuals are now reporting to the Committee symptoms consistent with those being suffered by other Gulf War veterans. In addition, Iraq has claimed a dramatic rise in reported cases of communicable diseases since the end of the Gulf War including typhoid, brucellosis, hepatitis and cholera.
Further, reports of Gulf War illnesses being reported are no longer limited to veterans of the Gulf War. Others reporting manifestation of these symptoms include:
* Department of Defense civilians who served in the Persian Gulf War.
* Department of Defense civilians working at the Anniston (AL) Army Depot and the Sharpsite (CA) Army Depot decontaminating equipment which was returned from the Persian Gulf.
* Spouses, particularly the spouses of male veterans, are reporting the following symptoms: chronic or recurring vaginal yeast infections, menstrual irregularities (excessive bleeding and severe cramping), rashes, fatigue, joint and muscle pain, and memory loss.
* Children born to veterans prior to the Gulf War. In many cases both male and female children born prior to the war have experienced symptoms similar to those of the veterans and their spouses.
* Children born following the Gulf war. Some reports have been published which suggest a high rate of miscarriages in the families of Gulf War veterans. Further, several reports have surfaced which suggest that there has been a high rate of physical abnormalities in children born to Gulf War veterans since the war.
U.S. Exports of Biological Materials to Iraq
The Senate Committee on Banking, Housing, and Urban Affairs has oversight responsibility for the Export Administration Act. Pursuant to the Act, Committee staff contacted the U.S. Department of Commerce and requested information on the export of biological materials during the years prior to the Gulf War. After receiving this information, we contacted a principal supplier of these materials to determine what, if any, materials were exported to Iraq which might have contributed to an offensive or defensive biological warfare program. Records available from the supplier for the period from 1985 until the present show that during this time, pathogenic (meaning "disease producing"), toxigenic (meaning "poisonous"), and other biological research materials were exported to Iraq pursuant to application and licensing by the U.S. Department of Commerce. Records prior to 1985 were not available, according to the supplier. These exported biological materials were not attenuated or weakened and were capable of reproduction. According to the Department of Defense's own Report to Congress on the Conduct of the Persian Gulf War, released in April 1992: "By the time of the invasion of Kuwait, Iraq had developed biological weapons. It's advanced and aggressive biological warfare program was the most advanced in the Arab world... The program probably began late in the 1970's and concentrated on the development of two agents, botulinum toxin and anthrax bacteria... Large scale production of these agents began in 1989 at four facilities in Baghdad. Delivery means for biological agents ranged from simple aerial bombs and artillery rockets to surface-to-surface missiles."
Included in the approved sales are the following biological materials (which have been considered by various nations for use in war), with their associated disease symptoms:
Bacillus Anthracis: anthrax is a disease producing bacteria identified by the Department of Defense in The Conduct of the Persian Gulf War: Final Report to Contress, as being a major component in the Iraqi biological warfare program.
Anthrax is an often fatal infectious disease due to ingestion of spores. It begins abruptly with high fever, difficulty in breathing, and chest pain. The disease eventually results in septicemia (blood poisoning), and the mortality is high. Once septicemia is advanced, antibiotic therapy may prove useless, probably because the exotoxins remain, despite the death of the bacteria.
Clostridium Botulinum: A bacterial source of botulinum toxin, which causes vomiting, constipation, thirst, general weakness, headache, fever, dizziness, double vision, dilation of the pupils and paralysis of the muscles involving swallowing. It is often fatal.
Histoplasma Capsulatum: causes a disease superfically resembling tuberculosis that may cause pneumonia, enlargement of the liver and spleen, anemia, an influenza like illness and an acute inflammatory skin disease marked by tender red nodules, usually on the shins. Reactivated infection usually involves the lungs, the brain, spinal membranes, heart, peritoneum, and the adrenals.
Brucella Melitensis: a bacteria which can cause chronic fatique, loss of appetite, profuse sweating when at rest, pain in joints and muscles, insomnia, nausea, and damage to major organs.
Clostridium Perfringens: a highly toxic bateria which causes gas gangrene. The bacteria produce toxins that move along muscle bundles in the body killing cells and producing necrotic tissue that is then favorable for further growth of the bacteria itself. Eventually, these toxins and bacteria enter the bloodstream and cause a systemic illness.
In addition, several shipments of Escherichia Coli (E. Coli) and genetic materials, as well as human and bacterial DNA, were shipped directly to the Iraq Atomic Energy Commission.
The following is a detailed listing of biological materials, provided by the American Type Culture Collection, which were exported to agencies of the government of Iraq pursuant to the issueance of an export licensed by the U.S. Commerce Department:
Date : February 8, 1985
Sent To : Iraq Atomic Energy Agency
Materials Shipped:
ing records)
Where does Life come from?
The origin of life or prebiotic evolution means the spontaneous generation of life in a 'primordial soup' containing small organic molecules in salt water. Such a process is generally believed not to be possible (or successful) in today's ecosystems, unless undertaken in controlled laboratory settings. The latter awaits experimental proof. In order to understand the spontaneous formation of life an appropriate definition of life must be at hand. Derived from an analysis of today's organisms life is usually defined at the cellular level. In this definition, the smallest or simplest forms of life are single cell organisms which include bacteria, archaea (halophiles and thermophiles; live in extreme environments), and protozoans (eukaryotic single celled microorganisms, e.g. baker's yeast, paramecium, or amoebae). All modern life forms share fundamental molecular mechanisms, most notably protein biosynthesis and the use of DNA and RNA for reproduction and energy metabolism. Based on these observations, theories on the origin of life attempt to find a mechanism explaining the formation of a primordial single cell organism from which all modern life originates. The primordial cell is thought to form itself through beneficial packaging of self-replicating units in lipid particles (liposomes or vesicles resembling modern cell membranes). The most pressing question is how closely modern organisms resemble a primordial cell. Evidence of prebiotic evolution is obtained through simulating and replicating such an event that happened about 3.5 billion years ago. Although biochemical evidence first obtained in the 1950s showed the spontaneous generation of amino acids in a replica of the 'primordial soup', most biologist now believe that amino acids which are the building blocks of proteins and peptides, today's essential tools in all life forms, were not important at this earliest stage and that proteins and enzymes were indeed preceded by RNA type molecules which still plays an essential role in modern metabolism including energy metabolism, enzymatic catalysis (e.g. protein biosynthesis), and processing and storage of genetic information. DNA, this modern molecular marvel and blueprint of life, may indeed have come into existence after the evolution of proteins as enzymes.
Over the last few years analysis of rocks found in Antarctic ice sheets and originating from Mars contain microstructures consistent with leftovers of Martian organisms because these structures so closely resemble structures or leftovers from bacteria on Earth. The interpretation of whether these deposits are really proof of (ancient) life on Mars are controversial but of enormous interest to biologists. Single celled life on Mars, even if extinct today, would corroborate origin of life theories. Proven or not, the possibility of a future prove is enough to stimulate research including theory building on speculative grounds. It is these theories vaguely supported by experimental evidence (fossil evidence in this case) that will spurn imagination and the design of experimental protocols to actively explore the Martian soil and atmosphere. A note of caution; even if future analysis would prove that life existed on Mars, it would leave open the possibilities that life has been imported from Earth or life on Earth originated from Mars (or some place else). What ever the outcome, the current quest of proving the ancient existence of life on Mars at least gives an excellent example of how scientists work and draw conclusions from observations when events cannot be recreated in the laboratory under controlled conditions as is the case in studying the evolution of life.
The Plague on Livestock
1 Then the LORD said to Moses, "Go to Pharaoh and say to him, 'This is what the LORD, the God of the Hebrews, says: "Let my people go, so that they may worship me." 2 If you refuse to let them go and continue to hold them back, 3 the hand of the LORD will bring a terrible plague on your livestock in the field—on your horses, donkeys and camels and on your cattle, sheep and goats. 4 But the LORD will make a distinction between the livestock of Israel and that of Egypt, so that no animal belonging to the Israelites will die.' "
5 The LORD set a time and said, "Tomorrow the LORD will do this in the land." 6 And the next day the LORD did it: All the livestock of the Egyptians died, but not one animal belonging to the Israelites died. 7 Pharaoh investigated and found that not even one of the animals of the Israelites had died. Yet his heart was unyielding and he would not let the people go.
The Plague of Boils
8 Then the LORD said to Moses and Aaron, "Take handfuls of soot from a furnace and have Moses toss it into the air in the presence of Pharaoh. 9 It will become fine dust over the whole land of Egypt, and festering boils will break out on people and animals throughout the land."
10 So they took soot from a furnace and stood before Pharaoh. Moses tossed it into the air, and festering boils broke out on people and animals. 11 The magicians could not stand before Moses because of the boils that were on them and on all the Egyptians. 12 But the LORD hardened Pharaoh's heart and he would not listen to Moses and Aaron, just as the LORD had said to Moses.
The Plague of Hail
13 Then the LORD said to Moses, "Get up early in the morning, confront Pharaoh and say to him, 'This is what the LORD, the God of the Hebrews, says: Let my people go, so that they may worship me, 14 or this time I will send the full force of my plagues against you and against your officials and your people, so you may know that there is no one like me in all the earth. 15 For by now I could have stretched out my hand and struck you and your people with a plague that would have wiped you off the earth. 16 But I have raised you up [a] for this very purpose, that I might show you my power and that my name might be proclaimed in all the earth. 17 You still set yourself against my people and will not let them go. 18 Therefore, at this time tomorrow I will send the worst hailstorm that has ever fallen on Egypt, from the day it was founded till now. 19 Give an order now to bring your livestock and everything you have in the field to a place of shelter, because the hail will fall on every person and animal that has not been brought in and is still out in the field, and they will die.' "
20 Those officials of Pharaoh who feared the word of the LORD hurried to bring their slaves and their livestock inside. 21 But those who ignored the word of the LORD left their slaves and livestock in the field.
22 Then the LORD said to Moses, "Stretch out your hand toward the sky so that hail will fall all over Egypt—on people and animals and on everything growing in the fields of Egypt." 23 When Moses stretched out his staff toward the sky, the LORD sent thunder and hail, and lightning flashed down to the ground. So the LORD rained hail on the land of Egypt; 24 hail fell and lightning flashed back and forth. It was the worst storm in all the land of Egypt since it had become a nation. 25 Throughout Egypt hail struck everything in the fields—both people and animals; it beat down everything growing in the fields and stripped every tree. 26 The only place it did not hail was the land of Goshen, where the Israelites were.
27 Then Pharaoh summoned Moses and Aaron. "This time I have sinned," he said to them. "The LORD is in the right, and I and my people are in the wrong. 28 Pray to the LORD, for we have had enough thunder and hail. I will let you go; you don't have to stay any longer."
29 Moses replied, "When I have gone out of the city, I will spread out my hands in prayer to the LORD. The thunder will stop and there will be no more hail, so you may know that the earth is the LORD's. 30 But I know that you and your officials still do not fear the LORD God."
31 (The flax and barley were destroyed, since the barley had headed and the flax was in bloom. 32 The wheat and spelt, however, were not destroyed, because they ripen later.)
33 Then Moses left Pharaoh and went out of the city. He spread out his hands toward the LORD; the thunder and hail stopped, and the rain no longer poured down on the land.
Footnotes:
1. Exodus 9:16 Or have spared you
Exodus 8 • View this Chapter • Exodus 10
Today's New International Version
International Bible Society
© Copyright 2001, 2005
A Closer Look into the TNIV Bible Translation
We begin this journey with a brief overview of the history of translating the Bible into English. Then we'll learn what experts and scholars have to say about the issues surrounding Bible translation. Finally, we'll learn what the Committee on Bible Translation (CBT) has to say about the newest major translation, the TNIV Bible, and how it compares to other translations.
Beaufort Scale
The Beaufort Scale was originally developed as a system for estimating wind strengths without the use of instruments. It was introduced in 1806 by Admiral Sir Francis Beaufort (1774-1857) of the British navy to describe wind effects on a fully rigged man-of-war sailing vessel, and it was later extended to include descriptions of effects on land features as well. It is currently still in use for this same purpose as well as to tie together various components of weather (wind strength, sea state, observable effects) into a unified picture.
The Beaufort scale is divided into a series of values, from 0 for calm winds to 12 and above for hurricanes. Each value represents a specific range and classification of wind speeds with accompanying descriptions of the effects on surface features.
Force
Description
Conditions
Wind speed (mph)
0
Calm
Smoke rises vertically
0
1
Light air
Smoke drifts
1-3
2
Light breeze
Leaves rustle; vane moved by wind
4-7
3
Gentle breeze
Leaves in constant motion; light flag extend
8-12
4
Moderate breeze
Raises duct and loose paper; small branches move
13-18
5
Fresh breeze
Small trees sway; crested wavelets on inland water
19-24
6
Strong breeze
Large branches in motion; whistling in telegraph
25-31
7
Moderate gale
Whole trees in motion
32-38
8
Fresh gale
Breaks twigs off trees; impedes walking
39-46
9
Strong gale
Slight structural damage to buildings
47-54
10
Whole gale
Large branches broken; some trees uprooted
55-63
11
Storm
Large trees uprooted
64-72
12
Hurricane
Widespread damage occurs
73+
ok bigray we all get the hint your a bigasshole so change your name to bigassholeray
walters...focus...let's get back on track with your question:
You should always...I REPEAT ALWAYS...print your effects (eq's,compressors,reverbs,delays,phasers,flangers,chorus,tremolo) in series parallel. If you purchased your HUM Remover effect, you should include that too.
Running your effects in series parallel will give you the best, most professional results.
If you get good with that, then try running your effects in diagonal...that will give you very interesting results almost 143% of the time.
i thought u guys were more creative than this u guys are artist and wannebe engineers so spill out the creavitive stuff
Woooops you got banned,,,,,,,,LOL :D
