B
Bigus Dickus
After some research, and on the advice of members here, I've purchased a pair of Yorkville YSMP1's (other thread just below).
In that thread, an interesting quesiton came up. I had asked if active monitors have a gain (volume knob), and someone replied that most active monitors have a gain control on the back. That would mean that there is a preamp section before the amp section in those monitors.
Someone else replied saying that wasn't correct, and that for most active monitors you either use the gain control on the mixer they are connected to, or for PC based systems you use the master level control in the computer.
If that is true, then for PC based systems is the level set digitally or in analog? In my specific case, the soundcard is a Delta Dio 2496, with 24 bit D/A converters and analog output identical to the Audiophile (two channels at least). I've read all the info I could find about my card, and there is nothing to suggest that it has an analog gain in the preamp section. In fact, I don't get anything suggesting it has a preamp section at all.
I was under the impression that these soundcards output a line level, just like a CD player would, and that a preamp is needed to adjust gain before power amplification. My manual says that maximum "gain" in the master level setting is 0db, and you can attenuate from there. I can't help but think this attenuation is done digitally.
If the master level is a digital volume control, then isn't that, well... bad? I mean, you're going through a lot of trouble to set levels in the mix, and so forth, and having the digital signal altered in the final stage before output would seem extremely counter-productive. If this is what actually happens, and the Yorkville's indeed have no gain adjustment, then purchasing a stereo preamp would seem to be in order.
Or, is it possible that the master level is actually adjusting the output voltage in the analog section of the card, and leaving the digital signal at full scale? This sounds pretty confusing to me. I can't imagine why you would adjust volume digitally after all the hard work in mixing/mastering, but I see nothing to suggest otherwise.
