B
Bigus Dickus
Got my the YSM1p's in today, hooked them up.
First off, they sound pretty nice. Not as nice as the type of home audio setup I am used to, but a drastic improvement over my previous Klipsch computer speakers.
These monitors have a "trim" knob on them that adjusts gain from -6db to +9db. Since they are capable of boosting gain, not just cutting, they must actually have a full powered preamp section complete with op-amps, not just an attenuation pot.
Also, the -6db setting is nowhere near tame enough for casual listening. These things can put out some sound when they're in close proximity to the listener.
Further, adjusting levels through soundcard controls is a no-go. Applications frequently reset the volume to maximum, and disabling application control of the audio drivers results in less than ideal results from Cubase. Also, changing levels while some application is currently playing material doesn't actually change anything, which is a pain if winamp or something similar is playing back something from the mixing clinic, and it's too loud. You have to stop the stream, shut down winamp, change the level, and restart, making sure to disable application control, and remembering to reenable it before launching Cubase.
Solution? I'll be looking for a simple stereo preamp, passive if possible, but it doesn't really matter... a couple of op-amps isn't going to degrade the sound enough to notice - no worse than a mixer does.
