preamp leds are almost clipping, meters are -12 to -24, faders 0
  • Thread starter Thread starter junplugged
junplugged
junplugged
Taking the slow road
This doesn't happen with mics but with line level. Wondering what's up in this case?
That sounds normal to me . . . line level should use all the dynamic range. On the other hand, you could get your mics a bit hotter.
thats what you get for running line level into a mic pre.
all my lines into the box have line/mic pots. If I increase gain from the source or if I do it w/ the trim pots, either way the clip lights turn red but I don't have as high of a reading on the meters than I would if I were using a mic, even if I had the mic going to gear turning it into a line level. I was recording a signal from tape, just wondering what the difference was.
The tape is -10. What is your soundcard input???
-10 or +4???
