Preamp into Preamp??
  • Thread starter Thread starter Jross
J
Jross
Can you hook up a Tube preamp into a standard preamp with no problems?
The only reason to do this is that the preamp has an A/D converter.
You *can* do it, but it isn't advisable......... you'd be incurring a lot more noise and degradation running the signal thru 2 gain stages like that, particularly if they're not top-end pres.
What about using the line in with no gain......wouln't it act as a passthrough?
Preamp -> Line in is fine. You said the second unit is your soundcard, right?
it would be tube preamp ---> line in of regular mic preamp w/ no gain added-----> soundcard
Or just tube pre ---> souncard.
