ashcat_lt
Amplitube also has an input knob, it does the same thing as the input knob in PodFarm, which is about the same thing as turning up the gain on the interface which is about the same as adding a preamp or booster before the interface, which is about the same as a TS at low gain with the exception of the tone shaping that the TS gives. It makes the signal going into the amp sim's "preamp section" louder, and that's a period.
Which is "best"? I would suggest that adding gain one way or another ITB is going to be quieter and cleaner than trying to do it with any analog device and so from a purely technical standpoint, it is "better" as far as transparently raising the level. It is quite possible, though, that the little bit of extra noise and possible harmonic content changes will actually sound better. AFA whether flat gain or the bandpassed version that you get from the TS sounds better... Well, the TS thing seems to be SOP for most of the current metal dudes, but I don't think that anybody in this thread actually shoots for those sounds on a regular basis. So why don't you just plug the things in and decide for yourself?
