Siruiz
Hi,
I was testing Prominy Hummingbird and I found a very interesting function.
You play the notes like C,D,E, etc on the keyboard-controller and Hummingbird gives automatically a chord for you (in the case, imitating a guitar chord).
You can chose between Major, Minor, 7th, 9th, Dim7 and so on.
So, you select Minor and type the note D, it will give D-minor chord, if you type E with Major chosen it will give E-Major chord.
I gave up of using Hummingbird because I don't have cpu enough, and nonetheless the plugin seems to work "inside itself", what I mean is that the score (like written on Ableton or other daw) is still, C,D,E, but the VSTi(instrument) will put the chord sound.
I started to think if there might be a plugin that would do the same thing but for any instrument(VSTi)?
Like, I could type C, chose major, and the plugin writes a C-Major chord on the DAW score.
It would help a lot to create harmonies to melodies. Does this sort of thing exist? Or something similar?
Thank you a lot.
Thank you a lot.
