A
Ape the Ghost
Please excuse my ignorance...I am an artist not a techie...
For many years I have been successfully recording using a 1997 Gateway running windows 98 and recording with Acid. I was getting great results but as you can imagine I had to employ many work arounds since the machine was slow to process and had only 6 gigs of hard drive.
So, I just bought a Dell Inspiron 1525...I want to use it as my workstation. I don't need a bunch of fancy stuff..I just want to record like I did before.
On the Gateway I ran guitars and mic into a Boss BR 8, used it's effects and ran that straight into the line in. Worked great but after I'd recorded 6 tracks or so the machine couldn't process quick enough so mixing was an issue. No problem, I worked around it. My main gripe was that the slow processor wouldn't let me do complex mixing and that I had only 6 gigs so I basically had to complete a project, burn to disc and wipe the hard drive clean to start the next.
On my Dell, I have downloaded Audacity and have begun to experiment with recording using a simlilar set up but am experiencing the most frustrating latency. I cannot record multitracks because the latency is impossible to work with.
I borrowed a friend's Line 6 ux2 and the latency is even worse. I have tried to install Asio but it downloads to my machine but then I don't know how to employ it.
I am seeking ANY advice on how to get back to most simple multi track recording possible. How can I get my latency issue fixed?
there are so many directions to research and I'm just lost...I'm really searching for the simplest route. Please help..I know I am asking a lot...but really I just need some gentle prodding in the right direction from some kind soul.
Thank you in advance.
