skippy
Bingo. So you were summing the two signals to mono, and not listening to them separately via either speakers or headphones?
skippy said:Bingo. So you were summing the two signals to mono, and not listening to them separately via either speakers or headphones?
Digidude824 said:is that the right or wrong way to do it?
bleyrad said:Since you're being so specific about wording, I'm going to have to disagree with you here. "Polarity" implies something electrical or magnetic, not sound pressure. Polarity deals with POLES - positive or negative. Positive and negative sound pressure will cause the same effect as having reversed polarity by creating the a likewise positive or negative electrical waveform output, but it is not in itself a polarity issue. It is a pressure issue.
volltreffer said:@skippy: you write that the maximum phase shift is 180?- which is DEFINITELY wrong. The phase shift of 180?(and every shift with 180?+ x*360? is just the one with the most obvious effect: total cancellation.
But in fact it is the phase shifts that are bigger than 180?that make the comb filtering sound like comb filtering...
volltreffer said:My point was that I do not alter the phase ***relationships*** in a signal by shifting it by 180deg. Therefore any signal with inteference to another...
