RICK FITZPATRICK
Hello everyone, I've been so confused by so many ideas here and there, its really getting hard to focus on what it is I am really trying to do in my control room design, so I outlined a few areas of uncertainess. Here are my conclusions. Maybe you can see some things I am missing here. So here are some true/false statements.
1. Room size. wlh. Ok, the thoughts Ive read here kind of boil down to these things.
A room will only support the development of low frequencys by the longest dimension of the room in relationship to the length of the wave. true/false.
2. The ratios of WLH determine how the modes are distributed, and each of these dimensions can be responsible for a frequency and multibles/close frequencies that form standing waves(in a rectangular room,and at the resonant frequency). true/false
3. The use of non-paralell walls/ceiling, will help stop the formation of said standing
waves, if the angle is a minimum of 12 degrees. However, the calculation of modes then becomes so complex, that even a professional will cringe. true/false
4. Since non-parallel walls/ceilings will will stop standing waves, there is no reason to calculate the modes, as the reason in the first place was to determine standing waves. true/false
5. The use of angled walls at the sidewall/frontwall conjectures of the the frontend of a control room, can reflect early reflections to the rear wall. And if the rear wall is at a distance x from the monitoring position, then the reflection from the rear wall will
return by a time delay, of which is determined by distance x. true/false
6. And if this time delay is suffecient enough, the initial wavefront may be monitored without the rear wall reflection confusing the ear of the engineer. true/false
7. The minimum distance x from the monitoring position to the surface of the rear wall
is determined by the speed of sound, and this initial time delay GAP should be a minimum of x milliseconds, in order for the engineer to hear the difference. true/false
8. This inital time delay x, is determined by the ability of the brain to determine the difference. true/false
9. The reflection from the rear wall, can be altered by means of diffusion and absorbtion, and is merely a matter of preference, depending on ones criteria for this preference. true/false
10 There are no perfect rooms. Therefore the criteria for a good room vs. a great room are determined by a consensus of experienced ears. And this consensus is not set in stone. true/false
11. This criteria, has however, evolved, by the demands of the recording capabilitys, and analasis of sounds behavior, and by the ability of consumer equipment to replicate the depth of professional recordings. And shall continue to evolve. true/false
12. Unless your recordings are going to be professionally mastered, then the depth to which one wants to design ones rooms, can be modified to a lower criteria. This level of critera, is determined by ones clientel, who, may or maynot, be demanding
enough to require a mix, which will ultimately be professionally mastered. true/false
13. To take on the designing, building, equiping, financing, recording in, and
taking responsibility for a homerecording recording facility, can be, a lesson in
total confusion, frustration, time and money wasting of, and relationship
threatening avocation, of enormous consequences. true/false
14. This thread has no use, other than to vent a few thoughts that plaque a disillusioned author who need to be remotivated, by truth, and perspective.
true/false
fitz
true/false
fitz
