B
Babycham
I was told by a few people, that AMD processor is better than a Pentium for doing music. MY question is why is it better and how?
Was true for some older VIA chipsets but it appears not to be for what's in the shops today.brzilian said:First of all, most P4/Intel chipset mobo combinations are pretty much guaranteed to be stable and reliable. You can coun't on not having too many issues/incompatabilities and conflicts with your audio cards,etc. The same is not true with Atlhons and certain mobo chipsets that are intended for those processors.
Secondly, the Athlon is a power hog. It generates absurd amounts of heat and requires a hefty CPU fan and a power supply with no less than 400W power capacity.
I also think this is quite misstated. While I can understand the general point you're making (kind of),... it's still pretty misleading. (read "wrong")brzilian said:I don't think buying the AMD to save a couple $$ is the way to go especially if you are setting up a computer for DAW work. First of all, most P4/Intel chipset mobo combinations are pretty much guaranteed to be stable and reliable. You can coun't on not having too many issues/incompatabilities and conflicts with your audio cards,etc. The same is not true with Atlhons and certain mobo chipsets that are intended for those processors. Just do a search here and you'll see how many times people have run into these problems.
Secondly, the Athlon is a power hog. It generates absurd amounts of heat and requires a hefty CPU fan and a power supply with no less than 400W power capacity. What does that translate to? One NOISY computer that you probably don't want in your recording studio.
If your primary use for a computer were anything else other than DAW work, I'd say go for the extra performance AMD gives you, but in this case the cons outweigh the pros IMO.
What are you, a Canadian?...and don't care aboot performance...
Anyway, it should be mentioned that the fastest processor you can buy is a Pentium 4.Hhhhmmm.... could beeeeeeee......elevate said:
What are you, a Canadian?![]()
Oops... did I forget to mention that??elevate said:Anyway, it should be mentioned that the fastest processor you can buy is a Pentium 4.
Another thing that's good about Pentium 4's is that they have temperature sensing mechanisms and will throttle down or even shut off to prevent cpu damage from heat. AMD has no such feature, which is kinda silly.
Yeah.. it's kinda stupid that AMD doesn't have that.... yet. And it is clearly true that P4 has the faster chip at the moment. But my advice for anyone looking to buy is "wait". All sorts of new stuff is gonna be comin' oat soon (fall) and prices are gonna be goin' through the floor on lots of stuff. The new AMD chip is comin', as well as DDR400, etc. etc. etc. AMD should regain the "crown" soon enough.
It's my opinion that this strategy just doesn't work. Something is always coming out soon. AMD's new chip is actually a bit delayed and besides, their 64-bit desktop cpu will be even later. Intel also recently unveiled their new Itanium which appears to be finally living up to the hype - preliminary benchmarks show it to have insanely high floating point performance, easily besting IBM's Power 4 which has 43 times more L3 cache. And all this at a mere 1Ghz. Anyway, point is you can play the waiting game forever and when you do decide to make your purchase, you will regret it in two weeks when prices drop.But my advice for anyone looking to buy is "wait".
