Pedal with multiple od or distortion modes
  • Thread starter Thread starter Alexxxander
To tame harsh or 'fizzy" sound, run a fuzz through a DS1 or OD1. Loads of sustain without the nasty noisy stuff.
I have an Ibanez TS808DX tube screamer, a tech 21 plexi and a Chandler 911 overdrive and I don't use any of them 99% of the time.
I am not fond of distortion. The Ibanez has two different distortions to switch between. I have been trying to sell the Ibanez and tech 21
for quite a long time. I guess no one else likes distortion?
I’m a composer, songwriter. I need various and versatile stuff. From jazz, folk to metal.
Give me the most versatile od and distortion units available. Brit, USA and other custom flavours. Enlighten me. Thnxx
I use several pedals and often just distorting amps. The trick is to set them so that rolling off the volume of the guitar changes the timbre. Distortion adds harmonics, the more distortion, the richer the harmonics. Which is not always what is right for a particular song.
Distortion also changes the envelope of a signal, creating a more even amplitude. Again, may or may not be right for a given track.
I have been playing almost sixty years. There's no trick to them, I just don't like the distorted sound produced by a pedal. Give me a small enough amp where I can crank it up and control a portion of the distortion, able to be controlled by my attack on the strings. I used to use two amps at one time. A Fender Pro Reverb and an Ampeg VT22. The VT22 for loud and clean and the Pro for Cranked and dirty. It got a little difficult lugging them around, especially the VT22 w/EVs. I used distortion in cover bands because I had to. When doing my own material I don't use it often.
I use amp distortion more often than pedals myself but pushing an amp with a gain stage before amplification is sometimes exactly what a part needs. I refuse to limit my tones to just those available with amps.
Wren & Cuff has made the BM-20
Do u know any other od or distortion pedals that have such big flexibility, options??
Thnx
I am about to put up the tube screamer and the Tech21 on ebay at lower prices than any there if anyone is interested.
Thnx
Take a look at the Boss ME-80. Multiple Pedals.....each of which can be adjusted. You can chain "pedals" and they can have the effect you want one each other.
Mick
  • Like
Reactions: RFR
Mick
That’s a fukn good digital stuff, but currently I need analog. Thnxx
Well......the ME-80 is fully analog controlled. It does have a digital readout to indicate the volume setting for each pedal (trust me that's handy) and for the integrated guitar tuner. Think of it as many, many Boss effects pedals put into one device with all the same analog components the pedals use.
Mick
Mick
It’s a COSM digital modelling stuff. Why do you call it analog??
Ha ha ha, you're fussy ! ?
You'll find what you're looking for, eventually.
Spend some time watching “That Pedal Show” or the JHS pedal YouTube channel .
Try different stuff out.
Seems this thread is unproductive. Any suggestions we present get rejected.
You gotta try different pedals out for yourself, see what works for you.
