Gtoboy
To tame harsh or 'fizzy" sound, run a fuzz through a DS1 or OD1. Loads of sustain without the nasty noisy stuff.
There’s lots of sonic options. ThnxxTo tame harsh or 'fizzy" sound, run a fuzz through a DS1 or OD1. Loads of sustain without the nasty noisy stuff.
I use several pedals and often just distorting amps. The trick is to set them so that rolling off the volume of the guitar changes the timbre. Distortion adds harmonics, the more distortion, the richer the harmonics. Which is not always what is right for a particular song.I have an Ibanez TS808DX tube screamer, a tech 21 plexi and a Chandler 911 overdrive and I don't use any of them 99% of the time.
I am not fond of distortion. The Ibanez has two different distortions to switch between. I have been trying to sell the Ibanez and tech 21
for quite a long time. I guess no one else likes distortion?
I have been playing almost sixty years. There's no trick to them, I just don't like the distorted sound produced by a pedal. Give me a small enough amp where I can crank it up and control a portion of the distortion, able to be controlled by my attack on the strings. I used to use two amps at one time. A Fender Pro Reverb and an Ampeg VT22. The VT22 for loud and clean and the Pro for Cranked and dirty. It got a little difficult lugging them around, especially the VT22 w/EVs. I used distortion in cover bands because I had to. When doing my own material I don't use it often.I use several pedals and often just distorting amps. The trick is to set them so that rolling off the volume of the guitar changes the timbre. Distortion adds harmonics, the more distortion, the richer the harmonics. Which is not always what is right for a particular song.
Distortion also changes the envelope of a signal, creating a more even amplitude. Again, may or may not be right for a given track.
Take a look at the Boss ME-80. Multiple Pedals.....each of which can be adjusted. You can chain "pedals" and they can have the effect you want one each other.Wren & Cuff has made the BM-20
Do u know any other od or distortion pedals that have such big flexibility, options??
Thnx
That’s a fukn good digital stuff, but currently I need analog. ThnxxTake a look at the Boss ME-80. Multiple Pedals.....each of which can be adjusted. You can chain "pedals" and they can have the effect you want one each other.
Mick
I like beer with alcohol, thnxSo what's with the analog need? Your inquiry here caused me to have an interest. The Strymon Sunset looks very strong for providing OD variation and options. It's definitely digital - but I own 4 of their pedals and they are top notch.
Well......the ME-80 is fully analog controlled. It does have a digital readout to indicate the volume setting for each pedal (trust me that's handy) and for the integrated guitar tuner. Think of it as many, many Boss effects pedals put into one device with all the same analog components the pedals use.That’s a fukn good digital stuff, but currently I need analog. Thnxx
It’s a COSM digital modelling stuff. Why do you call it analog??Well......the ME-80 is fully analog controlled. It does have a digital readout to indicate the volume setting for each pedal (trust me that's handy) and for the integrated guitar tuner. Think of it as many, many Boss effects pedals put into one device with all the same analog components the pedals use.
Mick
