alevy,
If you have a backing track that is already mixed and mastered, then it's likely that it's already set so the peak transients hit at or just under 0dB. So if you have added a vocal line, then you will need to reduce the level of the mixed track to allow room for the vocal. Normalisation isn't going to help you here.
So if you have for example:
Track 1 - (Mixed track)
Track 2 - (vocal overdub)
Then what you need to do is take a look a where this is being summed (usually the main output bus) and make sure that the two tracks combined aren't clipping by exceeding 0dB.
You may quickly realize that to get your vocals to a reasonable level against the mixed track without clipping, you have to reduce the volume of the mixed track considerably. This is likely because the vocal track you recorded has high peak transients but a low average signal level.
If this is the case, what you should do is throw a compressor on the vocal track to tame those peak transients - all while allowing you to bring up your average signal level.
The end result will be a "louder" sounding mix with no distortion.
Hope this might help.
Cheers,
Samantha
