Aoresteen
Member
I have 7 different guitar rack preamps. I'd like to be able to select anyone of them to record through.
1. I have a 1U Peavey 16LM rack mixer. I can patch each pre-amp to a seperate channel on the mixer and then leave the mixer outputs patched to a pair of inputs on my Delta 1010 audio interface. Or
2. Use a Tascam PB-32P patch bay and manually patch in whichever preamp I want to use to the Delta 1010.
Which approach is the better one? Or are they the same?
3. Now it gets a bit more complicated. I also have two effects units that I would like to use. What is the best way to add them to the signal path?
Guitar --> preamp --> mixer/patch bay --> FX 1 --> FX 2 --> Delta 1010 0r
Guitar --> preamp --> mixer/patch bay --> Delta 1010 then use effects loop out to FX 1, FX 2?
or should I insert the FX unit right after the guitar preamp?
Thanks!
Thanks!
