Even with the TRIM totally down, it still receive signal and OvLoad some times. Why it doesn't close totally, and why it overloads?
Should I configure always the conpressors?
This is a levels' problem. Compression' or limiting isn't the first go-to solution.
You might need to put a pad in line between the mic and input-an in line attenuator, or the mic's pad if it has one.
