Out of the Closet!!!
Dave,
Could you recommend an old tube reel deck that could be used as a mic preamp? There's plenty of them on ebay, but which one's better? Is it Ampex?
There is a bright light shining through all the cracks and making its way into the Analog Forum ... I think I'm starting to see it. :)
Clevo, I have found that there are many differing variables in bouncing tracks. I usually use two parameters, frequency range and stereo field. If you have two instruments that don't tend to use the full bandwidth of any track by themselves, say bass and cymbals, they can mix together very well without stepping on each other's toes sonically. The only drawback is that you have to have the tracks at the proper levels for final mix before bouncing them, which can be difficult. If you have a stereo image already planned before recording, you can occasionally work out your bounces to keep things apart via the two channels. I sometimes will use two tracks for a stereo bounce of all the instrumentals, then lay down vocals on top, and use the gaps for guitar fills and solos. You will probably want to decide which tracks are the most important in any mix and record them last, to avoid softening them up by bouncing. Whatever method you come up with, I would love to hear about, as this is an area that always has more room to learn about.
Yup, those two, the 388 / 246 setup, are also my favs. Thanks for sharing the picts, Dave! :)
Flangerhans, that was an excellent explaination!
Thank you!
That kinda blows my fire, as I was originally gonna open with...
I've seen track-bouncing from Jesus to Paul!
I'm sorry, I probably don't know exactly what that means, but I was on a John Lennon jag for a moment.
Okay, I'll agree with e'thing Flangerhans said, right at the outset. It's very concise and offers truth. Here's more from my side:
The "full collapse" or any "collapse" bounce should be taken for granted that the sound will deteriorate, somewhat. It's all a matter of degree. There is no such thing as a lossless bounce. Even in digi-m-al, but that's probably another post. :eek: ;)
So, the dreamey-eyed ideal of "10 (layers or virtual) tracks packed onto 4-tracks thru bouncing technique",... is not as good as it sounds on paper! Sometimes it can destroy a mix! :eek: ;)
With that being stated, bouncing is a useful tool in the studio to boost your production value, plain & simple, and it can be done with satisfactory results if you're really-really careful!
What I find useful and most tasteful are such things as:
~recording harmony vocals & bouncing them down to one track,
~recording harmonizing leads & bouncing them down to one track,
~bouncing a (light) percussion track in behind a lead or BG vocal.
~bouncing a BG vocal in behind a lead vocal.
Otherwise, what Flangerhans has stated is a good rule of thumb. You may bounce any two elements that don't tend to step on each other's frequencies, and you should be alright.
You may bounce your 4-track mix to another multitracker, but they should both be similarly equipped and high end.
A lot of folks will bounce an entire stereo mix to their 'puter in wav format, then burn an audio CD and record it back down to their priimary multitracker for 2 more tracks of overdubs, and generational loss is practically nil in this method, which is commonly known as the "external" bounce, which is quite different and offers better flexibility than the "internal" or "collapse" bounce.
The major advantages of external vs. internal/collapse bounce, is that with external bouncing: a) your primary tracks are not destroyed b) you may go back and remix the bounce later, and c) sound quality is certainly much better, in general, than with an "internal/collapse" bounce. [EDIT] d) you preserve the stereo image in the bounce, e) you may even add another "live" part to the stereo mixdown stage, so that boosts (track) count again! [/EDIT] Try it! :eek: ;)
A "collapse" bounce in it's purest form (for a 4-tracker) would be:
Record Tracks 1, 2 & 3 and bounce them to track 4, while adding a new part. [4]
Record Tracks 1, 2 & and bounce them to track 3, while adding a new part. [3]
Record Track 1 and bounce it to track 2, while adding a new part. [2]
Record Track 1 as your final track, and it's soup! :eek: :eek: ;)
That's 10 "virtual" tracks packed into 4-tracks thru the use of the internal/collapse bounce. It's done internally thru the Portastudio's mixer, and it collapses the audio by virtue of actually recording over the primary tracks, over and over, 'til what you're left with is all tracks of a bounced quality, less one. However, the adding of a "new" part (live and not off tape) during the bounce is somehow a saving factor in many cases to the overall quality of the track. It follows that you'd then want to use your most important part in the live-to-tape element of the bounce! [Planning! Planning! Planning!] :eek: ;)
No doubt, it's always better to try to bounce lesser parts, less important parts in behind more important parts. You don't want two bounced sounds to compete, 'cause that would turn to mush in a hurry.
I'd also recommend saving your most important parts for the end, when the last track gets recorded without an accompanying bounce, just as a 1st generation primary track. Unfortuanately, due to the structure of this method, that is always the last track, so plenty of planning and forethought has to go into the sequence of layered and bounced tracks, to then get your most important part to cap it all off on the very last track. Sounds simple, huh? :eek: :eek: ;)
I tend to use bouncing lightly, or with coincidental items that don't clash, as well as the disparate sounding items that don't clash with each other sonically. I much favor a one-generation "light" bounce of a taped background part with a more pronounced lead part. When you get to the point of bouncing 3 or 4 tracks together, things can get very compressed. If you don't mind your mixes sounding compressed and wall-of-soundish, as well as treading the danger zone of hiss awareness,... then radical bouncing is for you!
Nonetheless,... depending on how well you mix and match each track as you build your composition, [including setting levels, EQ, etc.], bouncing can actually be a good thing and not a disaster, but practically a godsend! It's all in the mix!
Having said this much, if you've followed me anyway,...
I'll state that bouncing is something I'd rather not do if I don't have to do it, but used em,... searching for word,... lightly, carefully, with forethought and planning it can be fine. You can't always tell if/when someone's done a bounce, if it's done right.
Okay, so if I'd rather not do bouncing, what's the alternative? Scope a larger number of tracks for your production. That's another post on buying gear, but someone on a budget who likes Portasudios and needs more tracks might want to look at the 488mkII. Okay, I said that's another post, but I'd bet my last dollar that any production would sound better produced in 8-discrete tracks on the 488mkII, than anything you could do similarly with bouncing techniques that added up to 8 parts on your 4-track. The value of buying up is there, though not always "expensive", it is a financial committment.
What's my other alternative to bouncing? Something commonly known as packing the tracks!
In a nutshell, it's a technique of grouping as many parts,... live-down-to-tape as possible, in a single live take of any track. Like, for instance, if you can play bass and sing backup parts simultaneously, do it! If you can do hand percussion while you sing lead, do it! If you and your girlfriend can harmonize together, do it! If you can play any instrumental or vocal part live in a band situation, do it! Pack the tracks right at the outset, and avoid bouncing! This, my friends, is a helluva better way to boost production value, and it's a real boost, it's not a second or third generation conglomeration of goop. It's a live track and it sounds that way. The downfall of many bounced tracks would be that they sound bounced. 'Nuff said.
OKAY, so if you'd like to know, I do have "sound samples" of what I've just described, above. The "internal" bounce, the "external" bounce", the "light bounce", the crappy bounce and the successful bounce, as well as plenty of tracks with no-bounce, and believe me, you can hear the difference! What I mean is, the types of things I've described, ideas on recording that are thrown around audio forums like this so often,... it puts in contrast the actual sonic value of a technique when it's actually heard. :eek: :eek:
The Track Bounce (is slightly overrated but is a good tool if used right).
The bottom line question is whether you want me to post specific examples of bounce/no-bounce combinations with simple setup explanations? I don't want to bore you to death! It's referencing my own home recordings. I'll warn'ya,... the reality of it is sometimes not pretty! :eek: :eek: ;)
ZZZZZZZZZZZZzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz!!!!!!!!!!!!!!!!!!! :eek: ;)
Yeah, of course! It's no problem. You may live as a gearslut vicariously thru me!
Any time!
Anyway, I know I go on a tangent or two now & then, but I hope I've floated at least a few ideas out there that you may find interesting or useful! :eek: ;)
If I didn't think I can get an optimal sound from very common an ordinary setups, I wouldn't say so.
If I didn't think I knew sonic differences between many popular formats, then I wouldn't pretend to.
If I didn't think I've gotten to a "snap-fit" philosophy in recording thru over 20 years of T & E,... I wouldn't even go there.
If I didn't think my recordings showed moments of excellence, or that they were devoid of interesting sounds and learning points, I surely wouldn't showcase them like I do.
You learn thru doing, and I don't consider myself as an academic who's spouting about stuff I've learned about in books. I've been there, and I've probably made every mistake in the book getting where I am now.
So not to pose as a know-it-all, you must know that I'm still a curious newbie at heart, and though I've tried and tested methods and skills, it's still an effort to produce any new recording competently, and even long-known skills and tricks of the trade must be practiced and put to use. Every new production, however large or small, puts me thru the process of learning again, but I can cut to the chase in many cases after decades of cutting my chops in this home recording game.
I feel stuff I do is very accessible to the listener, and I feel the technical points I make in posts are illustrated by my actual recordings, rather well. That's why I keep siting actual examples.
Anyway, the bottom line is that I do it all for fun. When it ceases to be fun, I'll stop, but I don't see that day coming any time soon.
I feel I have a few nice productions still left in me!
I won't get on a tangent or go on at length, but I struggle more with energy and inspiration more than with technology or methodologies of recording. Not to mention, just keeping up my chops. Musicianship and audio engineering are things that take constant practice to stay current, and to consistenly grow thru. You're never at a set place that represents "it" or "the end". There's always another production that puts you thru your paces again, from start to finish. That's what I've learned, over and over again.
:eek: ;)
Roland 606
Hey this may be a little off topic, but i see you have a Roland 606 drum machine. How many snare sounds does it make? Can you alter the sounds in any way? Im about to get into some drum machine sounds but i dont know where to start. I heard the "It wont be long" cover on your site and the drum machine sounds ok, but i was wondering if it made different snares and kicks or just those ones. Thanks
'Preciate the good word, Dave! I consider myself also a "curious newbie", and I think that anyone who works with recording learns something new every day. I have learned a LOT on this forum, and I'm sure there will be no end to it. You are dead on accurate about packing tracks, bouncing is always a last resort for me, and makes me lust after that Studer 2" 24 track that is high in my lottery dreams. Oh, BTW, nice closet!
Roland TR606:
One.
Yes. Volume: Up or Down.
There's a lot of machines out there now. When I bought the 606, it was quite a smaller field of choices.
Just those.
Thanx :eek: ;)
Yeah, sure. It's a learning process.
Thanx again!
PS: Sorry for the rants! I know I can't always be quick & concise...
like other people. It's all for fun, though.
Bouncing is not one of my favorite things to do on a recording, but I've done lots of it, and I've seen the good and the bad of it. I'd much prefer packing the tracks, adding a part at mixdown, a "lite" bounce, & buying up in track count as way better ideas than track bouncing. However, track bouncing does have it's place, and we all try to maximize our 4-tracks, too.
I'd much recommend the external bounce vs. the internal bounce, but of course I've done both.
I've used bouncing through the years and produced better tracks in some case, and other tracks when clarity or fidelity was clearly diminished.
I'm an amatuer home recordist, and though I've done a few outside jobs, it's a hobby for me. I feel I get good sound pretty cosistently these days, and fwiw I don't think success comes overnight. You have to try any and everything you can think of on an experimental basis, when you're thinking and functioning as producer. I've patched nearly every feedback loop, adjusted some of the harshest EQ, done some of the worst bounces, flubbed so many licks, done every heinous harmony... that you could imagine. I've done all that, & continue to do so from time to time. I've made some pretty good sounding stuff, too, in the long run. When you do something longer, the results seem to come along better and also quicker. That's just common sense, of course.
I've never claimed to have ever produced the "perfect" recording, as there really is no such thing. Each production is a learning process.
In every recording I've made, when you pick it apart, I feel they all have some successes and some mistakes in them, but it still holds together pretty well on tape & sustains it's listening value over time.
That's all for now! Maybe later! :eek: ;)
Okay, that's it, Mr Davemania!!! I've had just about enough!!! Where do you live!? You need a good ass kickin'!!! :mad: :mad:
.......................... :D
I think that's funny, except...
I don't get it!............... :eek: ;)
I just realized,...
I'm the tape-geek guy who showed up at every jam session, band practice & show and recorded e'thing!
Mostly stuff I played on, with some exceptions.
I'm still that way,... I still love throwing down to tape,... 'cept no band, no shows & older! :eek: ;)
It all happens right here,...
and you know it! :eek: ;)
Ready for more pix???
I am!................ :eek: ;)
Happy Easter '07! :eek: ;)
..................... :eek: ;)
