H
hypoxik
So is the Focusrite Liquid Saffire 56 a good audio interface to get? How is it compared to some of the audio interfaces. Heres the specs on it
Focusrite Liquid Saffire 56 FireWire Audio Interface at a Glance:
?Liquid Technology puts famous preamplifiers on your first two channels
?A staggering amount of I/O - 28-in/28-out - with six more Focusrite preamps
?Saffire Mix Control 18x16 DSP Mixer/Router
?Two separate headphone busses let you create two independent headphone mixes
?Easy monitoring solutions built into the software, for fast setup times
?Dedicated stereo monitor mix outputs with special "Anti-thump" circuit
?Front-panel 5-LED metering
?Handy loopback function lets you route audio between applications
?Includes a suite of Focusrite VST/AU plug-ins
?28-in/28-out, 24-bit/192kHz FireWire Interface
?Two Focusrite Liquid Preamplifier with ten different classic preamplifier emulations, with an eleventh 'flat' option (Based on API 3124+, Avalon VT-737SP, Focusrite Red 1 Quad, Helios Console preamplifier, Manley SLAM!, Millenia HV-3D 8, Neve 1073, Pultec MB-1, Telefunken V72, and Universal Audio M610
?Six additional Focusrite preamplifiers
?Separate line inputs on every channel
?Loopback function for routing audio between applications
?Suite of Focusrite VST/AU plug-ins, including Focusrite Compression, Reverb, Gating and EQ VST/AU plug-ins.
?Two separate headphone buses, which can each receive completely customized monitor mixes
?Front panel 5-LED metering
?2 banks of ADAT I/O (16 channels at 44.1/48kHz, 8 channels S/MUX at 88.2/96kHz, or 4 channel S/MUX at 176.4/192kHz)
?Word Clock I/O
?10 Line Outputs - two dedicated for monitors, with "Anti-thump" Circuit
?2 FireWire ports
?MIDI I/O
?S/PDIF I/O
?Mac/PC compatible
?Word Clock I/O
?2 FireWire ports
?MIDI I/O
?S/PDIF I/O
?Mac/PC compatible
