G
I don't see any reason for the vestibule. Usually you want a two door system, but in this case, you've got a window in your control room anyway. So any good that you get out of the 2 door system will be lost out the window.
So I'd extend the control room into the vestibule, and widen it a little. This is what I'd do:
Good ol' MS paint, haha. I do a lot of designs in paint for these forums, so i can use it quite well now.I guess my thought for the vestibule was 2fold... One, it would serve what vestibules are designed for, a transition point for controlling temperature. Being the HVAC end of things is going to be another challenge, I figured this would allow a space to control the loss of heat/air.
Two, further separation of sound from one space to another.
However, your changes make sense.
The addition of a window is an attempt to at least get some natural light into the Live Room w/o the hassle of having penetrations in it.
And I has thinking commercial grade French Doors throughout to further aid in allowing light through the spaces.
I like you changes... How did you alter my Drawing? It's very clean. Do you have AutoCAD too? SketchUp Maybe? If so, are you an Architect/Designer?
PS* I'm of Scottish Descent.
I'd put all the HVAC equipment, ducts etc, above the ceiling of the control room, if that's possible, as it seems you will be lowering the ceiling, and there will be a fair bit of room up there.
You're right, it would help to separate sound, but with the window, i don't see much point. And with the window in the control room, there is no need for the double door to the outside, as the sound will pass through the window.
I would certainly consider splayed walls. You will give up a bit of floorspace, but the improvement in sound will be immense.
I agree, the sound won't be as intense, so i think the window should be fine.
Get a single glaze for outside, and inside, as far away as possible, instead of a double glazed window. You don't need to angle them either. The only benefits of angling, are that you can see better through window, light reflections are aimed to the ground, and an acoustic benefit of having it non parallel with the opposite wall/window. However, it reduces the effectiveness of isolation.
If you are going to angle, make it very slight, and towards the back of the control room, IMO.
How will the ceiling be angled if left open? If angled towards the back of the control room, that's great, anything else won't be good.
edit: the roof is pitched. Leaving it open isn't such a good idea. You want the sound to be aimed towards the back, which will happen for the first half, but then the 2nd will reflect back towards you, screwing the sound. So unless you're gonna add absorption on the back half of the ceiling, then I'd suggest having a flat ceiling, or angling the ceiling towards the back, like so: (although this may not be practical)
What do you mean by Splayed walls? Different Angles?
Not Square.
You don't want parallel surfaces.
I would suggest going to John Sayers Forum and getting some fantastic FREE help.
I have a design thread, and a build thread over there.......
Rigid fiberglass? Hmm, there are so many different types/similar products: OC703 or 705, mineral wool, rockwool, bonded logic ultratouch... I assume you're from the US, so i'll let someone from over there direct you to a supplier, and help you choose the right stuff for you. Once you have the rigid fiberglass, you just gota frame it in wood, and wrap the whole this with fabric. There are many many posts about this here, if you search, and also have a look here.That Glazing detail was taken from the SAE website under window/door construction.
As for the ceiling, architecturally, it would be nice to get as much height in the room as possible, but form follows function, so I'll have to consider that.
You specified to specific panel type for the control room in your drawing.
Cab you provide a link to those panel types, or the materials to make them.
Hmm, splayed walls are certainly good. But for ease of build I'd suggest simple rectangular walls, and then fixing any acoustic problems with absorption.I would certainly consider splayed walls. You will give up a bit of floorspace, but the improvement in sound will be immense.
Square is bad. You never want square, especially not cube. Rectangular, is ok, with acoustic treatment, and splayed walls are good too. I usually suggest rectangular rooms, treating problems with rigid fiberglass panels. As does Ethan, i believe. Certainly check out that forum, and NL5s threads, and get all the free help you can!!!Not Square.
Square is bad. You never want square, especially not cube. Rectangular, is ok, with acoustic treatment, and splayed walls are good too. I usually suggest rectangular rooms, treating problems with rigid fiberglass panels. As does Ethan, i believe. Certainly check out that forum, and NL5s threads, and get all the free help you can!!!![]()
For some reason, i seem to trust ethan's advice, moreso than john or anyone. Although, i think if john was, still, the expert here, then i'd think differently.It's not very hard.
You won't find a design a John's site with parallel walls. To get the same effect with absorption, you would end up with a totally dead room. I would angle the ceiling as well - if that is at all possible.
Proper room design will have a bigger impact on your recordings than any gear purchase. Period. (and I'm a horrible gear slut!)
Doesn't it matter a great deal what angles you have etc? Adn aren't there a lot of "rules"? Actually, i'd lvoe to learn more about it. Any good info? I think i signed up to johns site, but i always end up coming back to here and forgetting other forums.
