FartSword
Everything I'm discussing here, I'm discussing in the context of voice overs / spoken word, as that's my main use.
I know there's some debate about microphone pre-amps when it comes to tube and solid state pre-amps. Some say the tubes warm up the signal, others say the tubes don't really do anything.
On YouTube I've seen some demonstrations where someone first plugged into their regular pre-amp then turned on and plugged into their tube pre-amp right away and other than a volume difference, the tube pre-amp sounded pretty much the same.
But then I've seen other videos where the people say you need to let the tube pre-amp warm up for about 30 minutes first to get its full benefit. And when they used the tube pre-amp after letting it warm up a while first, it sounded really good.
So, what's the current prevailing wisdom? Are tube pre-amps nothing more than snake oil? Do they make a difference? Or do they only make a difference after they've been warmed up for a while first?
